Brief Description: Install Electric Fuel Pump Vertical
Mounted the electric fuel pump to the bracket using a steel clamp and rubber cushion. Positioned the pump high enough to allow for smooth flow from the solenoid to the pump. Ensured that the rubber cushion was positioned around the pump before tightening the clamp. Reconnected the input and output hoses and tighten up all clamps.
