Brief Description: Carburetor Fuel Bypass Line Installed to Firewall
Connected a 1/8 ID clear hose on the carburetor fuel bypass fitting using a spring clamp. Drilled a 3/8 inch hole in the firewall about 3 inches left of center and 3 inches down from the top. Installed a 1/8 inch firewall pass-through fitting using blue lock-tight on the nut. Cut the fuel line to fit on the firewall fitting and secured with a spring clamp.
