Installed an AN 6 straight fitting on a segment of stainless steel hose. Connected one end of the hose to the firewall fitting and measured across to the engine sump. Marked the hose and removed it. Taped and cut the hose at the marked location. Installed a straight AN 6 fitting on the hose and then installed it between the firewall and the bottom of the oil sump.
