Measured out the location on the firewall for the oil return fitting. Drilled a 9/16 inch hole using a step drill bit at the marked location. Measured the line from the filter block to the return fitting and cut the hose to length. Installed a straight fitting to complete the hose and installed it between the filter block and the oil return fitting. Installed a straight AN 6 fitting on one end of a line. Measured from the return oil fitting to the output side of the engine driven scavenge pump. Marked the hose and removed it. Taped the hose at the mark and cut it. Installed a straight AN 6 fitting on the hose. Connected the hose to the oil scavenge pump and the oil return fitting at the firewall.
Measured and marked the location for the oil input line penetration of the firewall. Drilled a 9/16 inch hole at the marked location and installed an AN807-6D fitting. Installed a AN 6 straight fitting on a segment of hose and connected it to the firewall fitting. Measured the hose to the oil input side of the engine oil pump. Marked the hose, taped and cut it and installed a AN 6 straight fitting. Connected the hose from the firewall to the input side of the engine driven oil pump. This completes the engine side of the oil system.
