Measured out the dimensions of the battery and marked off one side on the 90 deg angle material. Mounted the material in a miter box and cut the end at a 45 deg angle. Completed the second 45 deg cut at the desired dimension. Repeated the processed for the other three sides of the top. Cleaned each piece of material in preparation for welding. Completed a test fitting to ensure a square box.
