Brief Description: Mounting Bolts for Air Filter Assembly
Installed two 1/4 inch aluminum bolts by drilling 1/4 inch holes through both plats. Careful to maintain vertical alignment of the drill. Reamed each hole edge to remove burrs. Placed each bolt through both holes and marked the correct length. Removed each bolt and installed a steel nut on the bolt before cutting the bolt to length. Used the steel nut to ensure that the treads were clean when it was removed. Installed the bolts through the plates around the filter and secured with the nylon wing nuts.
