Brief Description: Continued Layout of Instrument Panel Switches
Added switch locations for the beacon, the oil scavenge pump and the electric fuel pump. Moved the location of the volt gage to clear the right mounting bracket. Located the emergency battery power switch next to the volt gage. Placed the USB plug on the right side of the volt gage. Added locations for the master key switch and starter button next to the transponder position. Located the right and left ignition switches to the right of the radio position. Need to add a switch for the avionics master and the landing and interior lights. Additional positioning may be required.
