LARRY'S WEB SITE
Sopwith Baby
Left Wing Lift Cables
Installed a cable clamp on the upper left wing lift cable connection. Tighten the turnbuckle to check the cable tension. Cable length appears good. Connected the lift cable on the aft area of the lower left wing.
Left Wing Forward Lift Cable at Fuselage
Left Wing Forward Lift Cable Turnbuckle
Left Wing Aft Lift Cable at Fuselage
Sopwith Baby Home
2613
Brake System
Component
122
253
Configuration
Design
Documentation
125
Fabric Covering
94
310
376
Inspections
272
Testing
Wheels
410
