Brief Description: Left Wing Front Lift Cable Installation
Mounted the aft end of the outer rib on the wing stub. Mistake on mounting the lower edge which will require a rework. Rechecked the dihedral on both wings and adjusted to 3 deg up. Started on the left wing forward lift cable at the fuselage with a thimble and 3/16 inch crimp. Positioned the cable thimble and crimp and swaged it next to the thimble. Cut the excess cable end next to the crimp and complete two more swages. Checked good with the cable gage. Measured the cable to the top wing and cut to length. End of day.
