Brief Description: Wing Corner Bracing and Aileron Cable Rigging
Installed the last two wing corner brace on the left outer wing corners for both the top and bottom wings.
Adjusted the crossover aileron cable tension to bring the ailerons into neutral alignment with each wing. Found that the turnbuckle could not be tighten enough to completely align the ailerons with the wings. Also the crossover cable was in contact with the control assembly and would require corrected routing.
