Brief Description: Right Wing Tip Bracing and Aileron Cabling
Measured and cut angle aluminum to brace the right wing tip. Used 1/8 inch pop rivets to attach the angle between the wing rib and wing tip at the horizontal bracket. Repeated the process for the left wing tip.
Mounted a turnbuckle on the left aileron cable from the control stick and connected it to the lower aileron horn. Checked the alignment and control movement of the ailerons. Still more work to do on the control cabling.
