LARRY'S WEB SITE
Date:  10-18-2017
Number of Hours:  4.50
Brief Description:  Mounting the Right Wings
Constructed the support frame for the wings using 2 by 4's and 2 by 3's for a free standing frame wide enough to support the wings in their correct positions. Mounted the lower right wing into the frame and tried to fit it to the fuselage. Found that the attachments did not align completely with the wing spars being off by about a quarter of an inch. Applied a strap to the aft wing stub and bent it into alignment with the wing spars. Now found that the aft wing stub would not fit into the aft wing spar for the mounting bolt. A problem for another day.
Mounted the top right wing onto the support frame and on to the center wing section. Found that the spars did not align. There was a quarter inch difference between the spars. Used a strap and a large farm jack to complete the alignment of the wing and center section. Secured the wing and center section together with a short segment of orange strapping.
Right Wings on the Frame
