LARRY'S WEB SITE
Date:  5-2-2017
Number of Hours:  3.00
Brief Description:  Fitting the Aft Cockpit Cover
Laid out the material for the aft cockpit rim and marked the edges of the fuselage. Put a 70 degree bend in each end to fit over the sides of the fuselage. Fitted the material up next to the wing center section aft struts and marked that position. Using a section of scrap strut marked the outline on the material for the strut for each side. Cut out the marked sections and completed a trial fitting. Marked the areas where adjustments were needed and removed the material with a router bit.
Aft Cockpit Edge Material
