Brief Description: Fillin Welding on Complex Joints
Wire brushed each subject joint for a clean start. Set the fuselage side up vertically and clamped to a support brace, Welded the top of each intersecting tube to full the hole between each at the joint. Continued for each joint on the lower edge of the fuselage. Turn over the fuselage side and repeat for those joints.
