Brief Description: Checked Aircraft For Correct Configuration
Id several wires on the engine which needed additional securing. Used silicon tape to anchor the wires. Removed three zip ties from the engine wiring.
Found that the turnbuckle connections were loose and should be padded with washers. Added washers to all of the turnbuckle to fill the available space.
Installed the document holder in the right side of the cockpit containing the required document(s).
