Brief Description: Laced the Leather Cover on the Left Side Panel
Ran the lace through the far left grommet and pulled the lace to the end of the panel plus 6 inches. Put a loop through the next grommet set to the right and run the bottom lace through the loop and pulled each lace tight. Continued down the leather strip lacing each of the grommets to the panel until the last grommet and tied off the laces on the bottom side of the panel. Applied rubber cement to the knot and tucked the ends under the laces. Trimmed the ends and flowed the leather back to applied rubber cement on the leather. Then flowed the ends back and slide the ends under the leather cover.
