Brief Description: Begin the Install of the Leather Roll on Front Cov
Laid out the leather strip with the grommets installed on one edge and marked the location where each grommet fell on the front center edge of the cover. Drilled each location with a 1/8 inch drill. Enlarged each hole with a 1/4 inch drill. Deburred each of the holes. Attached the leather to the front cover with celo's through four of the grommets into a aluminum washer that had an 1/8 inch hole. Slid the underlying split rubber hose along the edge and then pulled the leather over the hose and marked the bottom side of the leather for the installation of grommets on that side. Removed the cleo's and laid out the leather for the installation of grommets at the marked locations.
