Brief Description: Construction of a Wing Gap Cover Strip
Installed safety wire on the left front lift turnbuckle and placed a access cover on the wing opening next to the turnbuckle.
Laid out the straight edge on the aluminum sheet and clamped each end for a 3 inch strip. Scored the edge of the ruler on the aluminum with a box cutter. Repeated the scoring three more times. Moved the straight edge to the other end of the aluminum sheet and clamped it to complete the 3 inch strip. Scored the aluminum four times on that half of the sheet. Removed the straight edge and flexed the strip along the edge of the table to remove it from the aluminum sheet. Filed both edges of the strip to remove any burrs. Used the vice-grip edger to go over both sides of the strip to complete the wing gap cover.
