LARRY'S WEB SITE
Date:  11-7-2019
Number of Hours:  2.70
Brief Description:  Continued Safety Wiring of Turnbuckles
Used a grease gun to lubricate the tail wheel shaft and the wheel bearing. The nipple on the wheel is reset in the rim and the standard grease gun does not fit completely on the nipple.
Installed safety wire on three turnbuckles on the right wing. On the lower forward turnbuckle the safety wire broke during the install. A second length of safety wire was installed and the turnbuckle and adjusted for correct fit. Continued the wiring of the other turnbuckles. The border around the cockpit is to be lined with a leather roll.
