Brief Description: Finished Right Side Cross Cable and Tighten Turnbu
Drilled a 3/16 inch hole in the right front strut under the bottom wing fabric. Mounted the cable to the strut and checked its' length across the front of the aircraft. It measured about a quarter inch long. Adjusted the cable through the thimble and crimped the sleeve next to the thimble. Slid the steel plate under the excess cable and cut away the end next to the crimp sleeve. Put a second crimp on the sleeve and checked that the cable end was covered. Mounted the cross cable to the top of the front right strut and to the bottom of the left front strut. Tighten both of the cables on the right side.
Thinking about the brakes not holding on the last taxi test Going to have to bleed the brakes again to see if that helps the braking.
Check and tighten each of the turnbuckles on the wings. Will start safely wiring the turnbuckles tomorrow. Checked the dihedral of each wing and hoped that the fires stay away form the aircraft building site.
