Brief Description: Connected Right Headset Plug, Added Labels on Inst
Put the wires back on the headset plug and tested the connections with the radio and headphones. Found that the output wire was on the wrong terminal and corrected it. Installed the plug back into the instrument panel.
Added labels for the accessory plug circuit breaker and the N number of the aircraft over the radio.
Acquired a tail wheel assembly from a Zenith kit which was parted out. Evaluated the possible connections in place of the existing tail wheel. The installation may require modification of the airframe in the tail area and the addition of several pounds.
