Brief Description: Finished the Trailing Edge on the Lower Left Wing
Added the 1/2 inch aluminum tube along the remaining length of the wing from the aileron. At each rib installed a gusset cut to fit over the rib, around the trailing tube and back over the bottom of the rib. Installed two 1/8 pop rivets in the top and bottom of the rib and one in the center of the gusset on the trailing edge. Checked all of the edges and pop rivets on the trailing edge of the wing and sanded smooth any ruff areas or pop rivets which stuck out.
Moved the wing from the work table and set it aside.
