Brief Description: Installed AOA Display Unit in Instrument Panel
Drilled a 7/16 inch hole in the back plate on the AOA display in the center of the marked spot for the Ethernet plug. Used the nibbler to remove the material to complete the square opening over the Ethernet plug. Installed the back plate on the display box by installing the two screw posts on the 9 pin plug. Installed the four screws in the corners of the box to complete the install of the back cover.
Drilled two 3/4 inch holes in the instrument panel centered on the marked opening for the AOA display. Used the nibbler to remove the material inside the marked area for the LEDs to shine through. Used the Dremel tool to smooth the edges of the opening and ensure clearance for the LEDs. Removed the paper covering on the smoked cover for the display. Mounted the display to the instrument panel by installing four #4 1/2 inch screws through the smoked cover and then into the display box. Used care on tightening the mounting screws on the display box cover to keep from cracking the cover.
Worked on filing out the insides of the strut mount to accept the vane pot in the end. Started filing on the other end of the strut mount to form to the curve of the strut. More work is needed to complete the fitting on the strut.
