Brief Description: Installed Lower Brace on Instrument Panel
sed the small vice-grips to close the clamp around the cross brace. Placed the flat end of the brace under the clamp and installed a #8 screw through the clamp and into the clip nut on the brace. Moved the other end of the brace down onto the instrument panel lower frame and installed a #6 screw through the frame into the clip nut on the brace. Tested the stability of the instrument panel while using the mixture control and found the operation successful.
Placed a coat of silicon on the back of the USB power supply box and stuck it to the left side of the magnetic compass. Discovered that the USB cable that had been ordered were ones for a micro connector and would not fit the ipad. Connected the power and ground wires to the avionics block for power and the ground wire to the common buss.
Labeled the wires for the radio bundle behind the instrument panel and label were pretend for the intercom connections on both sided of the instrument panel. Also labeled the wires from the radio push to talk buttons on the stick.
Drilled the left throttle handle to accept a small micro switch to serve as the intercom controls. Mounted the switch after talking them back to Moscow.
