Brief Description: Final Coat of Black and Brown Paint on Camouflage
Installed the left landing light lens by mounting the bottom flange with three #8 screws. Left each of the screws on the bottom flange loose. Applied a strip of duck tape to the top of the lens and pulled the lens tightly into the opening. Placed the top flange on the top edge of the lens opening and installed a #8 screw in the right opening on the flange Positioned the flange over the other two holes in the lens and installed two #8 screws. Tighten all of the screws around the lens.
Went over the green and black patches on the camouflage of the fuselage. Used the 1 inch brush for the body of the patch and then a small square paint brush to finish the edges. Used a 3 inch paint brush to cover the brown paint areas on the fuselage. Finished the right side of the fuselage for the brown paint as the day ended.
