Brief Description: Changed Oil Vent and Beacon Cutout
Checked the oil filler assembly and found that it was vented. Removed the vent filter from the oil tank. Removed the oil filler assembly from the input port on the oil tank and moved it to the vent port. Have to obtain a 3/8 inch plug for the open input port on the oil tank. Put a temp cover on the opening.
Wiped down more of the airplane frame to remove oil with a shop towel soaked in oil remover.
Lined up the 3 7/8 inch hole saw over the marked location and dented the center point. Place a scrap board under the panel and clamped it in place. Drilled the marked hole into the wood below the panel and continued to cut through the panel. Removed the hole and filed the edges smooth. Placed the beacon mount ring on the panel over the hole and drilled a 1/8 inch hole center in the center line screw hole. Placed a cleo in the 1/8 inch hole to hole the mount ring in place. Carefully aligned the ring over the cutout and drilled a second 1/8 inch hole center in another screw hole on the ring oppose the cleoed hole. Placed a second cleo on the ring. Drilled the remaining screw holes with a 3/16 inch drill. Removed the mount ring and drilled the two 1/8 inch holes out to 3/16 inch. Installed five 1032 anchor nuts on each of the ring screw holes.
