Brief Description: Trim Strip for Left Landing Light
Fitted the left top trim and removed the excess material on each end of the strip. Screwed down the trim to check fit. Marked the bottom anchor points for drilling when the lens is removed.
Fitted the right lens and marked the top for drilling the screw holes. Drilled the three holes and dimpled each one. Mounted the lens into the right wing stub and checked the fit. Noted a small crack on the lens at the mounting point next to the fuselage. Half to try a stop drill on the crack during the next work day. Marked the bottom drill points for later drilling.
Installed the overhauled altimeter into the instrument panel.
