Brief Description: Continued Wiring of Instrument Panel
Corrected the connection to the lighting circuit breaker by moving the instrument power wire to the gage circuit breaker and connected the instrument lighting wire to the lighting circuit breaker. Completed the wiring for the alternator warning light and the alternator power wire. Completed the wiring to the AMP display by splicing two wires to the display wires and connecting them to the firewall small terminal block. All wiring was labeled at each end and in the middle of its run.
