Brief Description: Start Wiring From Firewall to Instrument Panel
Created three flag labels for the carb heat probe wire and applied them to each end of the wire and in the middle. Crimped terminals on each lead wire and then soldered the ends. Place heat shrink tubing over each terminal and set with heat. Connected the lead wires to the marked terminals on the display module. Measured two black 16 gage wires to connect the master switch to the master solenoid and to the ground terminal block on the firewall. Put a two port mail plug on one end of the black wires. Put crimp terminals on the other end of black wires and then connected one to the master solenoid terminal and the other the ground block on the firewall. Measured a length of 18 gage green wire to connect to the CHT probe at the #1 terminal on the firewall block and to the blue wire from the display. Crimped a terminal on the end of the blue wire and covered it with heat shrink tubing. Printed three heat shrink labels marked CHT PROB and slid them in place at each end and the middle of the wire. Connected the two wires using a heat shrink coupling and then set each of the labels with heat. Connected the oil pressure warning light to the instrument power terminal block on the instrument panel. Connected the second terminal on the warning light to the firewall terminal block #3 position.
