Brief Description: Secured Instrument Panel and Reconnected Wiring
Inspected the mounting of the instrument panel to ensure that all wiring was clear of the cross member which it is to be attached. Installed three 3/8 inch long 1024 screws through the instrument panel into the fuselage. Reconnected each of the loose wires back on to their respective terminals. Doubled checked the connections to the instruments to ensure proper polarization.
