Brief Description: Complete Anchor Strips on Second Lens
Used the dremel tool with a ball cutting bit to slowly drill through the Plexiglas at the anchor points. Sanded the edges of the anchor strips to remove the excess material along the bottom edge of the lens.
On the second lens, measured the strips and marked the curvature at each end. Cut away the extra material. Applied silicone cement to the face of one of the anchor strips and placed it on the inside of the lens clamping it in place with two clips. Set aside to dry. Repeated the process on the second anchor and clamped it in place to dry. After the anchor strips were glued to the lens used the dremel tool to drill out each of the holes in the Plexiglas.
