Brief Description: Olive and Green Camo Paint on Upper Right Wing
Finished the application of the insignia on the bottom of the lower left wing. Laid the decal over the cable fairing and aligned the slit over the end of the fairing. Used the heat gun to form the decal over the fairing as the paper backing was removed. Used a scrap sheet of decal backing to slide under the decal to control the adhesion area. Continued to work the decal over the fairing alternating heat and hand pressure to complete the application of the insignia on the bottom or the wing. Moved the left wing rack into position next to the work table and tipped the wing off of the table onto the rack. Secured the wing to the rack and then moved the left wings back away from the work table.
Moved the right wing rack next to the work table and laid the top right wing onto the work table. Applied the olive and green camouflage paint to the top of the wing. The black paint and insignia are left for the next work day.
