Brief Description: Mounting the Inside Wheel Covers
Laid the inside wheel cover on the wheel assembly and drilled a 3/16 inch hole from the wheel hub through the cover. Mounted the stator adapter on top of the cover and bolted them all to the wheel assembly using a grade 8 bolt and self locking nut. Slid the wheel on the axle to ensure alignment of the cover and adapter and then drilled the remaining mounting holes. Installed the remaining five bolts and tighten all to normal torque. Repeated the same process for the other wheel assembly.
