Brief Description: Punched TAC Instrument Hole in the Panel
Measured spacing from the center of the instrument panel for two large instrument spaces. Center punched the left most position for the TAC. Used a step drill to drill out the center to 5/8 inches for the instrument punch. Installed the punch and tighten the bolt until the hole was completed. Removed the bolt and the punch from the hole. Checked the TAC to see if it would fit in the hole. The fit was a little tight so some sanding will be required in the next work day.
