Brief Description: Start of Upper Right Wing Covering Prep
Installed another angle brace on the wing tip for reinforcement.
Bent the top edge of the leading edge material down to provide a smoother transition to the top of the wing and to stabilize the edge material.
Added reinforcement angle braces to the end rib on the wing. Clamped the angles in place and secured with four 1/8 inch pop rivets on each of the center braces.
