Brief Description: Finished Lower Left Wing Patch and Racked It
Pulled the fabric tight along the end of the wing and ironed it in place. Doubled check the material for any loose areas or wrinkles and reset the fabric as necessary. Trimmed the front edge of the patch and along the end edge. Ironed all of the edges down securely. Ironed the patch at 250 degrees to bring tight. Applied fabric tape to all edges around the patch wiping away excess glue with a shop towel. Allowed the glue to dry and then did a final ironing at 300 degrees. Moved the wing to the rack with the help of Paul.
