Brief Description: Start Rivet Stitch Top Lower Left Wing
Turned the wing over with the top side up. Glued the wing tip tape down along the edge and iron it in place with the small iron. Measured and cut a tape to cover the light bracket top edge and glued and ironed it in place. Wiped the excess glue from the wing tip with a shop towel.
Applied a strip of ½ inch fiber tape over each wing rip centered over the stitch holes. Melted each stitch hole open with a soldering iron. Installed pop rivets in each of the stitch holes along the front half of the wing. The back half of the wing will have to be finished the next work day.
