Brief Description: Design of Emergency Fuel Shutoff Bracket
Evaluated the fuel tank outlet and measured the possible angles for the wire for shutting down the fuel outlet. Measured the position of the proposed bracket and the diameter of the fuel sump. Documented the measurements on the kraft paper for the bracket. Completed a proposed drawing for the layout considering force vectors and angle the connecting wire has to intersect the fuel shutoff valve. Set drawing aside for further consideration.
