LARRY'S WEB SITE
Date:  7-22-2016
Brief Description:  Begin Control Stick Construction
Mounted the top plate to the stick with three 3/16 inch pop rivets leaving one hole open. Turned the stick over and mounted the second plate with three 3/16 inch pop rivets. Drilled the forth hole through both plates with a 3/16 inch drill. Installed an AN3 bolt and two taps in the open hole. Slid the aileron control bracket on the control arm and positioned it per the plans.
Control Stick and Aileron Bar
