Brief Description: Rigging the Right Wing Lift Cables
Temporality configured the right wing lift cables. Cut the ferrule from the forward drag cable. Shorten the right wing drag cable by about one inch and secured it with a cable clamp. Currently out of 1/8 inch ferrules to secure the cable.
Install the aft lift cable by putting a ferrule on the cable and then running it through the thimble at the turnbuckle. Installed a cable clamp next to the ferrule and tighten security. Tensioned the lift cable and checked the angle of the aft spar. Loosened the lift cable and adjusted the drag cable to a 3.1 degree dihedral. Retentioned the lift cable and checked the aft spar at a 3 deg dihedral.
