Removed and replaced the aft bracket on the outside rib of the wing stub on the left side. Sanded the edges on the rib bracing on the left side. Ran the front lift cable to the top wing turnbuckle and did a test run using vice grips to secure the cable. Ran a second 3/16 cable through the aft lift bracket and thimble. Secured the cable with one crimp. Cut the excess cable from the loose end using a drimal tool. Measured the cable to the top wing lift turnbuckle and cut to length.
