Brief Description: Interconnecion oft the Ailerons
Mounted the interconnect pipe to the top left wing aileron. Clamped each aileron to the wing in the neutral position. Marked the pipe at the cut off location for the bottom aileron. Removed the pipe and cut it at the marked location and then installed the aluminum plug in the end. Reattached the interconnection pipe to the top aileron and adjusted the threaded ends to fit the gap and then attached the bottom end to the aileron. Repeated the process for the right wing.
Rechecked the alignment of each aileron and adjusted as necessary to have all ailerons aligned with each wing.
