Brief Description: Initial Rigging of the Right Wing
Raised the lower right wing up to a position of approximately 3 deg and clamped the support brace at that level. Raised the aft spar up to the same 3 deg with a 1.2 deg drop from the main spar. Using the digital level checked the position of the wing. Corrected the wing position to the stated degrees. Temporarily connected each drag cable to the lower wing brackets.
