Brief Description: Installed Ends on Outer Wing Support Struts
Aligned the end flange using a 1 inch pipe across the end of the strut. Drilled a 3/16 inch hole through the flange and strut and secured the flange to the strut with a 3/16 inch pop rivet. Repeated the process for two more pop rivets for that flange leaving a space between the first and third rivet for the AN3 bolt and tab for the cross brace cable.
Turned the support brace over and installed another flange aligned with the flange on the bottom. Repeated the above process three more times. The other ends of the support braces will have the flanges installed following a careful measurement of the distance between the two wings.
