Brief Description: Prepaired the Airframe for Move to the Hanger
Tighten all bolts in the empennage. Put cotter pins in all pins for the clevises and turn buckles.
Inspected the seat and marked areas where the seat was coming into contact with the seat belt anchors. Removed the seat and trim the areas marked. Repeated the process of inspection and marking to ensure the best clearance. Once the seat was trims correctly sanded the surface smooth and applied a coating of varnish.
Removed the seat back and trimmed each side to clear the seat belt attachments to allow opening for access to the aft storage area.
