Talked with Robert at Airdrome Aeroplanes about questions on the supports for the horizontal stabilizer. Found that I had not interrupted the drawing correctly. I needed two supports, one for the leading edge and one for the trailing edge on both sides.
When I returned from Airdrome Aeroplanes I removed the single brace from each side of the horizontal stabilizer. The connecting points were not correct for the new configuration. Considered adding additional mounting points but decided on using a single mount on each side of the fuselage to save the weight of the additional mounts. Removed the current mounting points and added a new mounting point on the lower longeron on each side of the fuselage. Ground the old attachment points smooth and painted all work areas.
