Brief Description: Forming and spot welding fuselage sides.
Layed out pattern per plans on long table. Cut top longeron to length. Cut and formed bottom longeron. Cut wood blocks and placed on pattern to hold longerons in place. Cut and shaped cross members to fit between longerons at plan locations. Using a mig welder, spot welded each cross member in place per plans.
This work was performed at Airdrome Aeroplanes facility.
