Back to the baffles. With the lower cowl installed I am able to get back to the front baffles and finish the installation. I left off with setting the front ramp angle. That completed I have been able to take the next few steps of marking and trimming. The front upper baffles go easily into place with some trimming around the prop governor. I still need to install the front angled gussets, add the tension rods, and start the final trimming process, so more later on that as well as adding the top seal. It will be nice to have this little chore out of the way.
