With all of the correct cutting parameters for engraving worked out I was able to engrave the two center stack switch plates that I was missing. One is for the ELT and rudder indicator, the other for the Flap switch, door indicator and seat heater switches.
I need to make a back light set up for both. I also need to wire the seat heater switches, flap switch and door indicator lights
