Leos Web Site
Date:  1-15-2018
Number of Hours:  10.00
Brief Description:  Install switch plates
At last the final version of the switch plates are completely installed.
Each plate had to be final shaped and drilled for mounting screws. Switch holes had to be adjusted where I didn't get the hole size correct.
Each group of switches had to be removed from the old plates, installed in the new plates, and in some cases additional wiring was needed (adding the taxi light switch, I forgot). Then the groups were reinstalled.
DONE ..... Woo Hoo
IP with purple light
Pilot side close up
Pilot side close up
Overhead front to rear
